CM6.01 and VG248 port registration failure
Feb 6th, 2008
I am having issues getting ports registered with CMv6.01. On the VG248 I get this error message on port 1.
SCCP 1 "Registration failed: Error: DB Config"
Anyone have any ideas. I do not have auto registration enabled in CM and I manually configured the gateway in CM with 1 port configured with an extension.
Rob Huffman Wed, 02/06/2008 - 13:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Todd,
You usually get this error on the VG when the config for a Port has been removed from CCM but the port has not been disabled on the VG itself. (in this case VG Port# 1)
Hope this helps!
Rob
