Pix 501 VPN question
Feb 6th, 2008
I have two pix 502 firewalls with an IPSEC L2L tunnel between them. The L2L tunnel establishes and is working fine. I added the dynamic VPN for road warriors to connect in but I get the following error
IPSEC(validate_transform_proposal): invalid local address
IPSEC(validate_proposal): transform proposal (prot 3, trans 3, hmac_alg 2) not s
Anyone got any ideas
husycisco Wed, 02/06/2008 - 13:54
Try this
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-md5-sha
clear config crypto dynamic-map outside_dyn_map 20
crypto dynamic-map outside_dyn_map 10 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 10 match address outside_cryptomap_dyn_20
isakmp policy 10 authentication pre-share isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
run clear xlate to reset current translations (internet and connections will be down for a second) then try again.
