dual static nat translations
Feb 6th, 2008
I am looking for a solution to use static nat translation on both sides of a router (not an ASA/PIX).
server-1 ( on fa0/1
server-2 ( on fa0/0
fa0/0 = ip nat inside
fa0/1 = ip nat outside
To translate server-2 on outside I use:
ip nat inside source static
That works for the outside.
server-1 can access server-2 by connecting to ip address
But I want to do this exactly the same for the inside.
So i would like to be able to connect from server-2 to server-1, not by accessing the ip address, but ip address
So should be translated to
In an ASA it is very simple by just using:
nat (inside,outside)
nat (outside,inside)
But how is this being done in a router?
RAJINDER UPPAL Wed, 02/06/2008 - 15:14
You need to do a source and destination NAT translation on the same device. You need to create a /32 route pointing to the FA0/0 interface. This is going to be VERY cludgy design and is not recommended.
