Routing Calls to Mexico PSTN through FXO on 3640 MGCP
I look here often for advice. You guys are great.
My setup:
3640 Router in Mexico, E-1 to US with a functional AVVID network. No PRI/BRI on Mexico router.
I'm trying to route calls from Mexico to local PSTN through FXO port. Calling the FXO port from PSTN rings the DN VoiP phone for 1/2 second then phone hangs up. FXO link light remains lit until unplugged. Call from VoiP phone to FXO gets a fast busy. I've tried changing from Loop Start to Ground Start and tried supervisory disconnect anytonebcptone MX on the voice port.
CCO recco'd an IOS upgrade with no results. Running MGCP and IOS Ver 12.2(46a) CCM ver 4.1(3)
jason-calbert_2 Thu, 02/07/2008 - 07:37
  • Bronze, 100 points or more
Can you please post a sh run from the router this might help. I assume that you are using Plar on the FXO?
Jason
jason-calbert_2 Thu, 02/07/2008 - 08:00
It doesn't look like your configs were uploaded. Thanks
Jason
jason-calbert_2 Thu, 02/07/2008 - 09:09
When you look in callmanager is the FXO port registered? Please check on that and also send a sh ccm-manager output. From the configs it doesn't look like MGCP is set up correctly.
If it is not then what is happening is your calling the FXO and it goes off hook at this point you will hear a ring and then nothing or a busy signal.
Jason
Issued the ccm-manager mgcp
Now a call rings until answered, some static then call drops.
Now:
MEX3600RTR#sh ccm-manager
MGCP Domain Name: MEX3600RTR
Total number of host: 1
Priority Status Host
Primary Registered 10.10.10.41
First backup Undefined
Second backup Undefined
Current active Call Manager: 10.10.10.41
Current backup Call Manager: None
Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 00:46:16 (elapsed time: 00:00:08)
Last MGCP traffic time: 00:46:16 (elapsed time: 00:00:08)
Last switchover time: None
Switchback mode: Not selected (Default:Graceful)
Now:
