1841 router ips problems
Answered Question
Feb 6th, 2008
Hi, I currently have a cisco 1841 router and i'm trying to upgrade it to ips v5 sigs
however it seem that it won't let me, all it will accept is the .sdf files,
i'm running ios c1841-adventerprisek9-mz.124-18.bin
however it doesn't seem to support the v5, can anyone let me a hand or point me in the right direction where i'm going wrong? Thanks in advance.
Correct Answer by Collin Clark about 9 years 2 weeks ago
I don't have enough memory, an upgrade kit has already been ordered, but I don't know when it will get here. I'll try an remember to test and post.
Try IOS version 12.4(15)T3
Overall Rating: 5 (2 ratings)
Collin Clark Thu, 02/07/2008 - 06:52
I made a cut sheet for when I had to deploy a bunch. Follow these steps and it should work. I'm assuming you have the correct DRAM/Flash and IOS.
configure terminal
logging console debug
crypto key pubkey-chain rsa
named-key realm-cisco.pub signature
key-string
30820122 300D0609 2A864886 F70D0101 01050003 82010F00 3082010A 02820101
00C19E93 A8AF124A D6CC7A24 5097A975 206BE3A2 06FBA13F 6F12CB5B 4E441F16
17E630D5 C02AC252 912BE27F 37FDD9C8 11FC7AF7 DCDD81D9 43CDABC3 6007D128
B199ABCB D34ED0F9 085FADC1 359C189E F30AF10A C0EFB624 7E0764BF 3E53053E
5B2146A9 D7A5EDE3 0298AF03 DED7A5B8 9479039D 20F30663 9AC64B93 C0112A35
FE3F0C87 89BCB7BB 994AE74C FA9E481D F65875D6 85EAF974 6D9CC8E3 F0B08B85
50437722 FFBE85B9 5E4189FF CC189CB9 69C46F9C A84DFBA5 7A0AF99E AD768C36
006CF498 079F88F8 A3B3FB1F 9FB7B3CB 5539E1D1 9693CCBB 551F78D2 892356AE
2F56D826 8918EF3C 80CA4F4D 87BFCA3B BFF668E9 689782A5 CF31CB6E B4B094D3
F3020301 0001
quit
exit
exit
end
mkdir flash:/ips5
configure terminal
ip ips config location flash:/ips5
ip ips name acme-ios-ips
ip ips notify SDEE
ip ips signature-category
category all
retired true
exit
category ios_ips advanced
retired false
exit
exit
end
copy flash:/IOS-S302-CLI.pkg idconf
configure t
interface fa4
ip ips acme-ios-ips in
interface vlan 1
ip ips acme-ios-ips out
end
To Update the signature on the router
copy tftp:///IOS-S###-CLI.pkg flash:
copy flash:IOS-S###-CLI.pkg idconf
Helpful Commands
show ip ips configuration
show ip ips signature
show ip ips signature counts
To load new signature packages, reload the router or remove and
re-configure the IPS policy on the interfaces.
int fa4
no ip ips acme-ios-ips in
int vlan 1
no ip ips acme-ios-ips out
int fa4
int vlan 1
Reference
http://www.cisco.com/en/US/products/ps6634/products_white_paper0900aecd805c4ea8.shtml
ddolbel Thu, 02/07/2008 - 13:03
hi thanks for your reply,
This all works fine
configure terminal
key-string
F3020301 0001
quit
exit
exit
end
mkdir flash:/ips5
configure terminal
until
this line ip ips config location flash:/ips5
when i do a ip ips ? these are the options available to me.
Router(config)#ip ips ?
deny-action Specify Deny action
fail Specify what to do during any failures
name Specify an IPS rule
notify Specify the notification mechanisms (SDEE, nr-director or log)
for the alarms
sdf Specify the location of the signature definition file
signature Add a policy to a signature
its like it still stuck in version 4 and
this ip ips signature-category
is just not a option
Router(config)#ip ips signature ?
<1-65535> Signature to be configured
This is my first 1841 that I have had to configure I have ips working fine on the 870 range.
I appreaciate any help you can provide.
Thanks again
Correct Answer
Collin Clark Thu, 02/07/2008 - 14:28
ddolbel Thu, 02/07/2008 - 15:34
ok will do, what feature set are you running?
thanks again for all your help.
ddolbel Thu, 02/07/2008 - 16:47
ok, you were right on the money thanks, i'm now running c1841-adventerprisek9-mz.124-15.T3.bin
and ips v5 is up configured and running, thanks so much for all your help
many thanks again
