is it possible to add static route in CCM6.1?
singh.andy
I know this wasn't possible in 5.0 & 5.1 1. Is it possible in 6.1, if so can anyone please share how?
bwilmoth
Level 5
Level 5
Static route configuration is not possible in cllmanager. rather you configure a route group, route list to point to the gateway or trunk to route the calls.
sorry for the confusion.. i meant IP route at the OS level (linux)
Best I can see is NO.
There IS a "show network route" command. Don't see a set command.
Don't see anything under "utils network" either.
TAC might be able to help you to put the command in. Why doesn't your default gateway handle the your "special" route?
