Routing over Easy VPN
Feb 6th, 2008
Hi guys, a year back i faced a task which required dynamic Routing over Easy VPN, i did it using DVTI, but the configuration was really complex. I wanted to know that any1 else tried it i.e. Dynamic Routing over Easy Vpn ? i hope every1 of you know that Gre tunnels cant be used with easy vpn, so if any1 has tried it then kindly also tell me how to do it
thanks
