To merge two 512Kbps links into one Mbps Line
shridhar19
I want to merge my two Lan cards having each 512 Kbps of speed int 1 Mbps im windows OS.
I am using two adsl broadband router each having 512 Kbps line ISP.
If it is not possible in windows OS please suggest the same for cisco router
Goutam Sanyal
Level 4
Level 4
Hi shridhar19
As per my knowledge :
Migrating two deferent links with two deferent adsl broadband route router is not possible. If you can terminate this two deferent links within a single router with deferunt interface- then it can possible via single Multilink mapping with your two deferent physical interface.
Goutam
Pls rate if it works.
zubaircco
As explained in the previous post, to merge 2 lines not terminating at the same point is not possible ( I Think). With regards to your question on Cisco Router, this can be done by combining the 2 links into a Multilink, eg. 2 x 128K lines can be multilinked into a 256K line. Remember you dont assign ip addresses to the seperate interfaces then, you create the virtual multi-link interface and assign an ip address to the multi-link.
Rate if this helps.
Zubair
Thanks Zubair,
You have clarified my big doubt.
It is only my pleasure. PLease rate my post. If you need anything else let me know. Thanks.
