Programs to get IP Phone Serial Numbers/Send Message to Phones
Feb 7th, 2008
Unfortunately a previous business partner has stolen my product code and is selling it under a different name, therefore I am now giving my software away for free. Descriptions:
http://www.mediafire.com/?9ffegzcgiwi
Serial Grabber for Cisco IPT Phones solves all of your Cisco phone auditing requirements. Simply enter your subnet range and IP Phone Scanner will bring back the Serial Number, MAC address, Directory Number and Model Name / Type.
* Supports Leading Cisco IPT Devices
* Retrieve Serial Numbers, MAC Addresses and More!
* Export data into CSV / Excel
Message Pusher:
http://www.mediafire.com/?89b50dxmvyi
Send test messages and a sound clip to ranges of Cisco IP Phones. Just associate a user to all of your phones, and then use the username/password to send to the IP Address range of those phones!
egrinkin1 Tue, 02/12/2008 - 07:40
  • Bronze, 100 points or more
Has anyone tried these? Are they safe? Do they work as described by Mattie?
~ Liz
pharden Tue, 02/12/2008 - 12:31
I loaded it to my Laptop ,that is how I was able to scan it. I tried to copy to my Call Manager but it would not run. Something about Missing DLL
pharden Thu, 02/14/2008 - 07:44
I tried these. I am sure they are not supported. however they seem to work. I scanned them no virus. I ran the serial numbers. it looks good. I ran the message thingy and it is creeping the heck out of prople. LOL
pharden Tue, 02/12/2008 - 12:22
Has anyone loaded this in CCM? I scanned it it looks safe....
mattiep00 Tue, 02/12/2008 - 13:05
To run these programs you will need the MS .NET framework V2, which is not installed on CallManager. You just run these applications from a PC on your network which is able to ping the phones you wish to scan. Insert the relevant IP address ranges and away it goes.
Ta,
pharden Fri, 02/15/2008 - 06:42
Has anyone else tried these? There seems to be some limitaions on the message pusher. but the Serial number program works very well
David Rickard Fri, 11/28/2008 - 06:28
Awesome little utility. Serial Grabber doesn't support ATA186 boxes unfortunately, but we've only a few of those, so I can do them manually.
This little tool saves me having to walk around to and do this manually. Thanks!
dezoconnor Sat, 11/29/2008 - 08:54
  • Silver, 250 points or more
As above, excellent tool, shame your business partner has done the dirty. Anyone know if it'll locate 7912's?
Cheers
