02-07-2008 12:31 AM - edited 03-03-2019 08:36 PM
hi everyone,
i'm a bit confused about the smallest member of the asa family, and i couldn't find any solid info regarding this. what do i need to connect to the fa0/0 (default "outside" vlan) in order to get a wan connection? can it be a simple dsl modem or does it need to be a router? thanks in advance!
Solved! Go to Solution.
02-07-2008 06:49 AM
It can be a DSL modem (Ethernet side only) cable modem (Ethernet side only) or a router (Ethernet side only). Basically anything that is Ethernet is OK.
02-07-2008 06:49 AM
02-08-2008 05:12 AM
thank you!
