02-07-2008 01:20 AM
Hi all.
Anyone know if there is a way, when I login to a router via telnet or ssh, to print on screen (like motd message), last succesfully login of the user?
Like on linux...
Daniele
02-08-2008 06:24 AM
Daniele
IOS does not track login history for individual users. So I do not see how it would be possible to have that displayed at login time.
Rick
02-11-2008 01:55 AM
Rick, with these commands I can track login:
login on-failure log
login on-success log
Now I solve my issue with autocommand con line vty, but I thought that there is a better way.
Daniele
02-11-2008 05:00 AM
HI Daniele, [Pls Rate if HELPS]
Naturally, your requirement is different. You wanted to get displayed as how in LINUX.
In CISCO Router it is not possible. But,
"login on-failure log"
"login on-success log"
>> Will generate a SYSLOG message for every Successful Login & Failure Login attempts but this is not same as in LINUX.
Refer the Attachment having the CISCO Login Enchancement feature in IOS.
Hope i am Informative.
PLS RATE if HELPS
Best Regards,
Guru Prasad R
