CM Inter cluster trunks with Voice Gateway..
Answered Question
Feb 7th, 2008
I have CallManagers & Callmanger express in many sites, all the local extensions are starting from 1 (1XXX). I want to enable calling between sites through VoIP. What is the best practice? Did somebody did this configurations before?
Please check the attachment for further understanding.
Correct Answer by thomasarun about 9 years 5 months ago
give access number for each locations and using discard digits discard the access number in route pattern.
Overall Rating: 5 (1 ratings)
thomasarun Thu, 02/07/2008 - 03:45
Do you hav a ccm in all sites if so u can use intercluster trunks otherwise u have to use dial-peer in GW's
create intercluster trunk with remote cluster IP and select that trunk in route pattern
route pattern eg:511.1XXX and there is an option for discard digits select "predot" there
haarisalibaig Fri, 02/08/2008 - 02:43
I have Callmanager in big sites & callmanager express in my small sites. but all the site extesnsions are starting from 1XXX
Correct Answer
thomasarun Fri, 02/08/2008 - 03:13
