Warning message
creting Network Looped
Feb 7th, 2008
1)User want to Access W Via A1->L2 Switch->Router C->Router W->
2)In present Scenerio B2 is connected to L2 Switch,L2 switch is connected to Router-c and B2 is also connected with B1,and B1 is connected to A1 & A2.
2)Propersed Scenerio is that Now We want to Connected A1 to L2 Switch Directly.
3)Vlan EFG(1.1.1.0/24) is configured in B2 and B3.
4)Vlan XYZ(1.1.1.0/24)is going to congiured in A1 & A2.
5)IN A1 & A2 there is no routing entry for 1.1.1.0/24 (towards B1)
6)B1 have static routes towards B2 (Ip route c 255.255.255.255 B2)
7)WE are going to connect Switch A1 with L2 Switch.We create vlan XYZ(1.1.1.0/24) in Switch A1 & A2.
)Question is:-Vlan EFG Create in B2&B3 with 1.1.1.0/24,same has configured in Router-C, and same we are goin to Create in A1 & A2.Can the network looped in this scenerio?
irisrios Wed, 02/13/2008 - 07:32
  • Silver, 250 points or more
Problem would arise in L2 switch when it comes to packets for 1.1.1.0/24 network. It might have to choose between A1 and B2. Probable a static entry of 255.255.255.255 should help.
