Problems routing calls between CME and CCM
Feb 7th, 2008
Iam having issues routing calls from a phone registered to CME to a CCM phone
Calls in the CCM-CME direction works perfectly fine
On the CCM the following things have been done
Configured the CME as H323 gateway
Created non gatekeeper controlled ICT trunk
Created a route pattern for the destination and pointed to the above gateway
On the CME
configured a dial-peer with a destination pattern and session target pointing to CCM
Any Ideas what could be the problem?
Narayan
thomasarun Thu, 02/07/2008 - 03:58
which one u r using for calls from CM to CME
intercluster trunk or H323 gateway?
select the h323GW in RP for calls from CM to CME and try calling from CME to CM.If still its not working check ur CSS and partition configs in CCM
royalblues Thu, 02/07/2008 - 04:43
THis is what i did
Configured an ICT trunk on the CCM
Then created CME as H323 gateway
route pattern points to the ICT trunk
If i remove the gateway config, it does not work
I think i am getting confused now as to what iam exactly using :-(
Narayan
thomasarun Thu, 02/07/2008 - 08:22
Wat i said is point the Route pattern to h323 GW And wat abt the partitions of phone...
royalblues Thu, 02/07/2008 - 08:42
There are no partitions configured on the system
The RP for eg 15xxx is configured to point to CME (configured as H323 gateway)
BTW i got to make it work somehow
Narayan
