Position of Device Pool for ICT remote PABX
Feb 7th, 2008
  • Silver, 250 points or more
I have a ICT to another cluster which I wish to set the calls to use g729 across this link
Set up
Cluster A - phones A ICT to Cluster B phones B
Calls within Cluster A use G711
Calls within Cluster B use G711
Between clusters i.e over the ICT need to use G729
Cluster A phones are assigned Device Pool A which contains Region A
Cluster B phones are assigned Device Pool B which contains Region B
Within the region A
within Region A G711
to Region B G729
Within Region B
to Region A G729
within Region B G711
What Device Pool/ Region do I assign to Cluster A ICT to force calls to use G729
I can understand that calls within the cluster the CCM know what regions setting to apply as it knows about the called phone set up - DP`S, Location etc but if the called handset is across the ICT or to another PABX via GW`s how does the CCM know what to assign - is it because you would create a new DP called ICT and create a new Region called ICT and only assign G729 so all calls use g729?
thanks
jason-calbert_2 Thu, 02/07/2008 - 07:30
  • Bronze, 100 points or more
You are correct create a new device pool called ICT and a new region called ICT. Set the region to use G729 and in your new ICT device pool use the region ICT.
You would then assign the device pool ICT to your intercluster trunk
Hope this Helps
Jason
iptuser55 Sun, 02/10/2008 - 02:45
Jason
Thanks for the confirmation
