unable to ping inside host-Remote access VPN
Feb 7th, 2008
I have configured Remote access VPN in ASA 5520 ,ver7.2.It's connecting from outside by using cisco VPN client.but after connecting I am unable to ping any inside host.It's not pinging firewall inside interface also.
Please guide me into this matter.
acomiskey Thu, 02/07/2008 - 06:28
Could you post the config?
Check the config for "crypto isakmp nat-traversal".
Also, to ping the inside interface you need to add "management-access inside".
jpodolanko Thu, 02/07/2008 - 11:09
I had the same problem on an IOS router (871). My solution was one of two things. I downloaded the most up-to-date version of the VPN client ( as opposed to the version I had or it was a software firewall (Norton 360). I have two different computers. One works just fine...the other connects but no traffic passes through. Here is what I have:
Computer 1 (working)- VPN Client v5.0.02.0090 and Network Associates Enterprise VirusScan.
Computer 2 (not working) - VPN Client v5.0.00.0340 and Norton 360.
I highly doubt it is the VPN Client, but sometimes you never know. Check your software firewall and try disabling it. Let me know how this works.
