bundled SRST
Feb 7th, 2008
  • Silver, 250 points or more
I have a new bundled SRST box and I`ve configured ccm-manager fallback etc and the mgcp. Sh ccm-manager shows it is registered and I`ve configured some FXS ports -all good but when I try to create the E1 controller I can not do it- Try to set up the ISDN SWITCH TYPE and I get an error also there is no option of isdn in the conf t ? list . Also how do I check the SRST version to confirm the correct S/W is already installed - sh ccm-manager only shows whether it is registered or not . Should not bundled Router come with all the S/W loaded and if so how do you confirm?
mhurley131 Thu, 02/07/2008 - 06:06
Make sure you do the following command first:
card type e1(or t1) then the slot it is in
You won't be able to do the switch type command until you tell the router what type of card it is.
