2 Routers 877
Feb 7th, 2008
Regards to all, I have to realize a configuration of a simple VPN, in a point I have this ip address: 80.38.x.x, with this LAN: 192.168.1.x And in other one sedate I have this ip address it publishes: 80.37.x.x, with this LAN: 172.26.0.x.
That configuration would have to apply for his(her,your) functioning? Thanks to all
aijaz802 Sat, 02/09/2008 - 00:27
You can create a IPSEC/GRE tunnel b/w them... The following is example for GRE..
Site A
interface Tunnel1
description VPN Tunnel to Site B.
ip address 192.168.201.1 255.255.255.252 (use any unused ip with /30 mask)
tunnel source DialerXXXX
tunnel destination 80.37.x.x
ip route 172.26.0.x 255.255.255.0 Tunnel1
ip route 0.0.0.0 0.0.0.0 Dialerxx
ip route 80.37.x.x 255.255.255.255 Dialerxxx
Site B
interface Tunnel1
description VPN Tunnel to Site A.
ip address 192.168.201.2 255.255.255.252 (use any unused ip with /30 mask)
tunnel destination 80.38.x.x
ip route 192.168.1.x 255.255.255.0 Tunnel1
ip route 80.38.x.x 255.255.255.255 Dialerxxx
You need to configure the dialer setting for ADSL.
Rate this if it helps..
*aijaz*
