Which VPN clinet to use?
Feb 7th, 2008
I recently purchased and installed a PIX 506e which came with VPN Client 4.6. I see from your download site that 4.8 and 5.0 clients are available. Our laptops all use XP. Which VPN Client should we be using and why?
Thank you,
John
Collin Clark Thu, 02/07/2008 - 09:40
  • Purple, 4500 points or more
Version 5 has added support for Vista. Since you're all XP the latest in version 4 would be fine or the latest in 5. Typically the VPN client is pretty stable and the latest version usually contains minor bug fixes and enhancements.
