Replacing a cluster member in a 3750 stack.
Feb 7th, 2008
Say I have a setup like this:
cluster enable core 0
cluster member 1 mac-address 0011.2196.d800 vlan 303
cluster member 2 mac-address 0011.5cc2.b500 vlan 303
cluster member 3 mac-address 0011.9247.b500 vlan 303
And the second cluster member switch dies and needs to be rma'ed.
To add that switch in so it will take on the config of the second switch, would it be as simple as:
conf t
cluster member 2 mac-address [new mac] vlan 303
exit
write mem
And then plugging it into the stack?
Overall Rating: 5 (2 ratings)
bwilmoth Wed, 02/13/2008 - 10:02
  • Silver, 250 points or more
If you have to replace a switch on the stack that is not the master, is a member then there is no need to turn off the whole stack you can just replace the device by taking out the stackwise cables on the back and putting the other one in. But on this case if you want to keep the current master as the master of the stack then you will have to turn off all members of the stack to avoid that other devise get elected as the master. Otherwise if you dont want to have this device as the master then you can
just disconnect this one and another device will be elected as master, once you are ready to add the previous master to the stack, the this one will be added as another member of the stack. Remember that once the master is disconnected the stack will be reloaded so another device can be elected as the new master.
