router to router VPN routing and multicast routing
Feb 7th, 2008
Hi, All,
I have a situation that I am struggling with. We have one main branch with 10 remote branches on a frame-relay networks. We are running EIGRP and Multicast rouing for VOIP phones. Recently I added 2 remote branches via LAN to LAN VPN to the main hub.
VPN works but I couldn't get eigrp routing information and multicast routing pass through the tunnels.
Do I have to do something special to get this routing information to pass through?
trustcisco Thu, 02/07/2008 - 09:21
You can use reverse route injection between your router or asa and the internal router to distribute the vpn tunnel routes to the inside router if that is what you need to do.
