Router/switch command requirements
Answered Question
Feb 7th, 2008
Can anyone tell me what specific commands need to be configured on devices to be completely managed and monitored by Ciscoworks?
Correct Answer by Joe Clarke about 9 years 3 months ago
Yes, the logging and the trap statements are for CiscoWorks syslog analysis and DFM respectively. If you are using MARS for syslog, you can choose to send syslog messages to MARS exclusively, or send them to both RME and MARS. I do recommend you still send syslog messages to RME as RME can react to certain messages, and kick of a config or inventory collection in near real-time.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 02/07/2008 - 08:22
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is really a loaded question since it depends on the type of device, desired protocols/protocol versions, authentication scheme, etc.. For a standard IOS device for which you want to use SNMPv1/v2c and telnet with VTY authentication for management, you will need this:
enable secret ENABLE_PASSWORD
logging CISCOWORKS_IP
snmp-server community ROCOMM RO
snmp-server community RWCOMM RW
snmp-server enable traps
snmp-server host CISCOWORKS_IP traps ROCOMM
line vty 0 15
password VTY_PASSWORD
transport input telnet
g-pate Thu, 02/07/2008 - 09:45
I assume the logging is what sends the syslog events to CW, and the SNMP-SERVER is what sends the TRAPS. What if something like MARS is being used in the network? I don't know much about MARS, but my understanding its a central repository for managing events across multiple platforms. How does this tie in with CW?
Correct Answer
Joe Clarke Thu, 02/07/2008 - 09:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
