VPN: Having problems allowing multiple connections
Feb 7th, 2008
I have two road warriors that have broadband and are able to connect to the vpn with virtually no problems but when a third user who has a verizon card trys to connect it won't allow him to connect, unless i clear the crypto isakmp. Then he is able to connect but then the other users are not. I turned on debug to see what going on. can someone help!
husycisco Thu, 02/07/2008 - 14:59
  • Gold, 750 points or more
Hi Eddie,
Issue command sh ver and check if you have enough VPN peer license.
eddied1963 Thu, 02/07/2008 - 15:14
husycisco,
This was the results of the 'sh ver'
It say's IKE peers Unlimited so I think I do
Cisco PIX Firewall Version 6.3(3)
Cisco PIX Device Manager Version 3.0(1)
Compiled on Wed 13-Aug-03 13:55 by morlee
CCX up 7 hours 18 mins
Hardware: PIX-506, 32 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 8MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0050.54ff.b821, irq 11
1: ethernet1: address is 0050.54ff.b822, irq 10
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 2
Maximum Interfaces: 2
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Limited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
Serial Number: 480350848 (0x1ca19280)
Running Activation Key: 0xd0ca14d7 0xd9505ca8 0x029ca1e2 0x28f92281
Configuration last modified by enable_15 at 08:44:40.216 MST Thu Feb 7 2008
husycisco Sun, 02/10/2008 - 03:24
Eddie,
I suggest you to upgrade your IOS to 6.3(5) first. Second, make sure you have isakmp nat-traversal 20 issued in config
