Discover Not Starting,
Joe Clarke Thu, 02/07/2008 - 08:39
Check to make sure you do not have an SNMP access-list applied to that community string in the config. If you do make sure the IP address of the CiscoWorks server is allowed by the ACL. Next, make sure there are no firwewalls or other ACLs between the LMS server and the switch which could be blocking SNMP. You can run debug snmp packet on the switch to see if the SNMP requests are actually making it.
000642: Feb 7 13:12:53.894: SNMP: Packet received via UDP from 10.9.3.116 on Vl
an9
000643: Feb 7 13:12:53.894: SNMP: Report, reqid 1, errstat 0, erridx 0
internet.6.3.15.1.1.4.0 = 21
000644: Feb 7 13:12:53.894: SNMP: Packet sent via UDP to 10.9.3.116
000645: Feb 7 13:12:53.934: SNMP: Packet received via UDP from 10.9.3.116 on Vl
an9
000646: Feb 7 13:12:53.934: SNMP: Report, reqid 2, errstat 0, erridx 0
internet.6.3.15.1.1.3.0 = 21
000647: Feb 7 13:12:53.938: SNMP: Packet sent via UDP to 10.9.3.116
Sorry about that.
2008/02/07 16:39:18 main MESSAGE DiscoveryMain: Properties will be read from C:\PROGRA~1\CSCOpx\campus\etc\cwsi\DiscoveryStatus.properties
2008/02/07 16:39:19 main MESSAGE DBConnection: Created new Database connection [hashCode = 6240509]
Common trust user is: admin
User name in Security context is: admin
log4j:ERROR No appenders could be found for category (CTM.common).
log4j:ERROR Please initialize the log4j system properly.
2008/02/07 16:39:21 main MESSAGE DCRDevWrapper: Fetching DCRDeviceIDs
2008/02/07 16:39:28 main MESSAGE DCRDevWrapper: Finished fetching DCRDeviceIDs
2008/02/07 16:39:28 main ERROR DCRDevWrapper: Unable to fetch DeviceIDs from DCR
2008/02/07 16:39:28 EvalTask-Devdiscovery-01 WARNING DevdiscoverySMFGetDeviceType: SNMP unreachable device at: 10.9.1.1 will not remap SMFFactory
2008/02/07 16:39:28 main MESSAGE DiscoveryMain: Properties will be read from C:\PROGRA~1\CSCOpx\campus\etc\cwsi\DiscoveryStatus.properties
2008/02/07 16:39:28 main MESSAGE DCRDevWrapper: Closing DCRProxy
Joe Clarke Fri, 02/08/2008 - 12:17
This indicates there is a problem accessing the devices in DCR. IT also appears you have an old version of Campus Manager. Exactly what version of CM is this?
