Unity user's web access address
Feb 7th, 2008
Hello All,
I can't remember what's the web address that we give to users in order to handle their voicemails. I am looking for the equivalant address of <CCM IP address/ccmuser> in unity. I have used it 100 times but can't remember it. We are unig unity 4.2.
Overall Rating: 3.7 (3 ratings)
mightyking Thu, 02/07/2008 - 11:41
Thanks guys,
What username and password is used for login?
Thanks again,
Rajesh Revuru Thu, 02/07/2008 - 12:10
Assuming you have enough licenses. If you have integrated your unity with AD, please try using your AD credentials.
That should work
mightyking Thu, 02/07/2008 - 12:28
The voice mail is not integrated with the existing exchange therefore there's no AD credentials. This is a voice only implementation.
mattcalderon Thu, 02/07/2008 - 18:05
Start>>>>Programs>>>>>Microsoft Exchange>>>>>Active Directory Users and computers, and find the alias or name you want to log in with. Right click on that name and reset password. Then log in with that alias and the new password
mightyking Fri, 02/08/2008 - 07:07
Thanks Mat, it worked
Do I need to reset the password for everbody or there's somewhere that I can change it once for all?
Thanks again,
mattcalderon Fri, 02/08/2008 - 09:05
There is a setting i think in the subscriber template that sets that password. you may want to check there.
