CCM and SQL DB name question
Feb 7th, 2008
Hi dear forum, I have two servers (Pub and Subs), but why the SQL database name of my Publisher server display as "LOCAL", Is there a way to update that name like my CCM Publisher because I can't to reestablish a broken CCM SQL subscription.
Thanks a lot for your suggestions
Jaime Valencia Thu, 02/07/2008 - 11:27
when you install CCM by default all the SQL managers will only show as LOCAL, if you want to have it named after the server name
open SQL manager
right click on local and choose delete SQL server registration
right click on SQL server group and choose New SQL server registration, you will get a wizard and a list of available servers, if the server is not there type the name of the server and add it
go thru the wizard, you should see after it finishes
