Migration - VPN 3000 to ASA5520
Feb 7th, 2008
I work with the ASA's quite often but not the 3000 concentrators. We're going to migrate a customers security pretty soon and about 75 remote access VPNs.
My question is, can the users / passwords / group passwords be exported from the 3000 or possibly saved to a text file? Id rather not have to call everyone and rebuild all of the tunnels due to passwords being unknown. Thanks in advance.
srue Thu, 02/07/2008 - 11:16
  • Blue, 1500 points or more
to my knowledge you will have to start from scratch. Maybe this time authenticate to a RADIUS server.
shawnreis Tue, 03/18/2008 - 12:38
Did you ever find the answer to this question?
I would be curious to learn how you did it?
d.donnelly Tue, 03/18/2008 - 16:43
I actually just implemented pretty much the exact same - VPN3000 to ASA 5520 - The customer only gave me the config file from the concentrator after a lot of cajoling - They wanted to start from scratch with no useless config.
I only had about 10 Remote Access VPN groups to implement so I just did them manually - Half an hour with the VPN Wizard, used a mixture of Local, RADIUS and RSA authentication, worked out pretty nice.
Let me know if I can help anyone out with anything similar...
