CLI Connect Problems
Feb 7th, 2008
Sorry if this is a dumb question, but here it goes. I can connect successfully with GUI Client and profile. When I try using vpnclient connect myProfile user xxx pwd xxx I get an error stating VPN connection terminated locally by the client.
husycisco Thu, 02/07/2008 - 15:24
  • Gold, 750 points or more
Hi Tim
Because you are trying to establish conenction via command prompt while VPN client's GUI is running. Right-click the VPN icon i taskbar at right-bottom and click exit. Or in Task manager, locate vpngui.exe and terminate the process. Then try running the command again
