Reload router using Ciscoworks
Feb 7th, 2008
I would like to reload a router using Ciscoworks. How can I do it?
tarapulka Thu, 02/07/2008 - 14:57
You can use the Reload task to schedule reload of devices. In order to get the reload configuration box you need to create a new Netconfig Job (RME -> Config Mgmt -> Net Config -> Net Config Jobs)
persepolis77 Fri, 02/08/2008 - 06:35
Oh yeah, I just tested it. It is as easy as other jobs.
I actually asked this question, because when you want to reload the router, you need to press on Enter to confirm the reload, which can not be done by Ciscoworks (oressing Enter), but I just tested with a template with "reload" command, and it worked fine.
I should have tested before asking ;-)
Thanks anyway for your help.
