Cisco IP Communicator on LWAPP
Feb 7th, 2008
Hi, I just migrated our WLAN to LWAPP. Now it seems out Cisco IP Communicator won't work on the new WLAN and it gets stuck at the registering phase. It works on the LAN, VPN, but just not on the new LWAPP WLAN now. Anyone encounter this issue?
douhanm Sat, 02/23/2008 - 08:40
you have the option 150 on the dhcp scope for the wlan?
agiaccone Tue, 04/15/2008 - 12:58
  • Bronze, 100 points or more
Maybe in Preferences you have fixed the Network interface to use for connecting and determining the device name ?
If you get to Preferences->Network you can easily check it.
Alberto
