Calling number doesnt appear
Feb 7th, 2008
i have Cisco PGW200 and AS5300, where the GW is connected to PSTN over E1's and im using the 1st time slot for SS7 signaling, the customer at PSTN dials 0800 number to access the IVR, the call is running very smoothly, but the calling number for the call leg "PSTN to 0800" doesnt appear in isdn setup message :S
attached is the GW configurations
scpage Thu, 02/07/2008 - 17:50
Hi, capture an mdl trace of the incoming ss7path on the PGW.
mml> sta-sc-trc::confirm
make the call
stop the trace
mml> stp-sc-trc:all
exit mml
Find the call using 'N'
Use option 'C' to convert to TRC file.
Attach the trc file.
mohannadhabaq Sat, 02/09/2008 - 03:34
thanks sir for the reply,
im responsible of the AS5300 GW only, i have asked the PGW team to provide me with the trace, and im writing down the output of the debug isdn on the GW, where the calling number field doesnt appear at all
*Feb 8 22:42:50.804: ISDN Dc3/2 SC Q921: User RX <- INFO sapi=0 tei=0, ns=76 nr=20
*Feb 8 22:42:50.804: ISDN Dc3/2 SC Q931: SETUP pd = 8 callref = 0x026C
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE980838F
Exclusive, Interface 0, Channel 15
Facility i = 0x9E8100036774640000002E49414D2C0D0A4743492C37663637326131316437363531316463393434393030303362613166383936640D0A0D0A
Progress Ind i = 0x8183 - Origination address is non-ISDN
Called Party Number i = 0xA1, '80099801'
Plan:ISDN, Type:National
*Feb 8 22:42:50.804: ISDN Dc3/2 SC PACKET: L2IF_SendPkt:
source_id (0x200), state (0x0),
dest_id (0x20A), event (0x141),
sapi (0x0), ces (0x1), call_id (0x0),
chan_id (0x0), int_id (0x653AC170), free_pkt (0x1),
pkt (0x62D67030), msecs (0x0), priority (0xA)
scpage Mon, 02/11/2008 - 13:59
Thanks for the debug. So it appears either the service provider is not sending the calling number or perhaps the PGW may not be forwarding it. The mdl trace from the PGW should clear this up.
tareqrebhi Tue, 02/26/2008 - 01:36
I like to participate because i have as this case but in other results.
1. Case description:
Calls are been dropped by my AS5400 when it receives calls without dialer ID.
Example when any dial number which is terminated by my AS5400 but when AS5400 sees no Calling ID the AS drops this call… do you have any idea to make my AS to pass all calls with or without ID number.
2. case:
i have comments if you can answer them:
1. my customers will dial 55004444 to reach IVR or when they dial 55004444 IVR will active and forward them to other destinations ….ok.
I have this configuration are these correct or not?
I used these commands:
call application voice TCLware.1.2.3 tftp:// 1
call application voice TCLware.1.2.3 language 1 en
call application voice TCLware.1.2.3 uid-len 8
call application voice TCLware.1.2.3 pin-len 6
call application voice TCLware.1.2.3 set-location en 0 tftp://
call application voice prepaid redirect-number 55004444
2. For destination-pattern .T I have a lot of mobile carries here 092xxxxxxx, 091xxxxxxx,093xxxxxxx…etc. Also I have land lines :01xxxxxx,02xxxxxxx,03xxxxxx….etc
So that I put ( destination-pattern .T ) do you have other solution for all these destinations?
I don't know advanced configuration for this case…. If you have other design for AS5400 can help me I will be thank but remember my country code is 218.
NOW when i put application TCLware.1.2.3 at Inbound dial peer the calls for outbound & Inbound are not pass I mean my service down.
dial-peer voice 102 pots
incoming called-number 55......
forward-digits all
dial-peer voice 200 voip
destination-pattern 55......
progress_ind setup enable 3
session protocol sipv2
session target ipv4:
codec g711ulaw
Again, why calls stop?
Do I need configure the application under the VOIP dial peer… please can give example?
Do I need to configure new DP for my responded IVR's number as follow:
dial-peer voice 106 pots
incoming called-number 55004444
forward-digits all
dial-peer voice 202 voip
destination-pattern 55004444
codec g711ulaw
Thanks for any help.
tareqrebhi Tue, 02/26/2008 - 01:45
Dear mohannad,
can help me in this case:
i need to configure the emergency call numbers at my AS5400 as: Public Security 111- Civil Defence 112- Police Rescue 113 etc.
i have configured my AS with DP and it is live and give the service.... now how i can configure these new emergency call numbers, do i need new DP?
really i don't know how .... any help?
thank you.
