LMS 3.0 syslog reports
Feb 7th, 2008
Recently noticed an interesting thing with the Unexpected Devices syslog report: sometimes I see in there the syslog messages from the devices that are managed by RME, for instance a device's syslog messages would go into the normal syslog reports (Severity summary, 24-hour) yesterday and today I see the messages from the same device, only in the Unexpected devices report.
Maybe such devices are going between the RME managed / unmanaged states?
Joe Clarke Thu, 02/07/2008 - 22:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This would not be possible unless the device is being removed from RME (i.e. some manual intervention). Check the RME audit log under RME > Reports > Report Generator > Audit Trail to see if there are any records pertaining to this device.
dmitry Fri, 02/08/2008 - 07:47
Checked this log, there is nothing about the devices that show the strange behavior.
I attached a doc with the syslog fragments for a particular device that shows the problem. This device was added into the LMS about 4 months ago.
Another thought, all the devices added into DCR using the DNS names (diplay name, host name is the same and no domain defined (using the resolv.conf search)). Once a device is added and goes into the Normal state in RME, does RME query the DNS each time it receives a syslog message from that device (it should not really have to)?
Joe Clarke Fri, 02/08/2008 - 12:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
How are these messages showing up in syslog_info. What are the DCR attributes for this device?
dmitry Fri, 02/08/2008 - 14:23
The source syslog messages for both types (Unexpected and normal) look the same format wise (in the attachment).
When the device was added only the desplay name, hostname, primary username + password, RO community were set (LMS uses TACACS (not ACS mode) to get to Lev 15 without enable).
In the DCR export CSV has also the IP and the domain name (discovered / resolved by DCR). The CSV is in the same attachment
Joe Clarke Fri, 02/08/2008 - 15:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
SyslogAnalyzer maintains a cache of device lookups. Whenever the inventory changes for a device, the cache is invalidated. This will cause SA to look up the hostname in the message, then iterate through each interface on the devices in inventory looking for a matching IP. This whole thing can fail if the lookup on the hostname fails. This failure can be transient (as it appears to be in your case). The clear workaround is to improve resolver response time. This can be done by adding local hosts entries, or adding multiple DNS servers.
dmitry Fri, 02/08/2008 - 16:21
This what I was thinking too, will set a dedicated secondary DNS zone in BIND off of the corporate W2003 DNS servers, see if it fixes the issue
Thanks for helping with this
