Configure ASA to allow traceroute responses
Feb 7th, 2008
How do you configure the ASA's to allow icmp traceroute responses through the firewall?
Example below:
C:\>tracert -d www.foo.com
Tracing route to www.foo.com [216.234.246.150]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.10.31 <-- Fictitious ip
2 <1 ms <1 ms <1 ms 192.168.1.1 <-- Fictitious ip
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 16 ms 16 ms 16 ms 216.234.246.150
1cmerchant Fri, 02/08/2008 - 05:46
Here is one way to do it:
access-list Outside_In extended permit icmp any any unreachable
access-list Outside_In extended permit icmp any any time-exceeded
access-list Outside_In extended permit icmp any any echo-reply
swharvey Fri, 02/08/2008 - 08:43
I wish I could say that works, but we've already had the following object-group in place for some time, and the timeouts still occur:
access-list acl-outside line 2 remark permit ICMP permits
access-list acl-outside line 3 extended permit icmp any any object-group icmp 0x39f88eb2
access-list acl-outside line 3 extended permit icmp any any echo (hitcnt=413608) 0xe22b3df2
access-list acl-outside line 3 extended permit icmp any any echo-reply (hitcnt=215003) 0xbfd87324
access-list acl-outside line 3 extended permit icmp any any unreachable (hitcnt=205341) 0xfbeab6da
access-list acl-outside line 3 extended permit icmp any any time-exceeded (hitcnt=26955) 0x23448f6f
Could there be an icmp inspect issue? Currently we are on v3.2.3 and icmp inspect is enabled.
swharvey Fri, 02/08/2008 - 09:46
TAC had the answer. On the FWSM's, icmp fixup and icmp fixup error are not enabled by default.
I enabled both and the default policy-map now allows traces:
