Stop Fax From Triggering Calls
Feb 7th, 2008
I have one PSTN line connecting a) to a fax machine b) to an FXO port and DSL port of a 2801 router. FAX and phone use different numbers.
The router is running ccme. I have connection-plar opx command on the FXO port to direct the calls to a group of ip phones. The problem is that the ip phone rings when a fax comes in. Is there a way to stop that?
Thanks.
Overall Rating: 2.5 (3 ratings)
sadbulali Wed, 02/13/2008 - 13:51
  • Bronze, 100 points or more
Try Bug - CSCee1538.
paolo bevilacqua Wed, 02/13/2008 - 14:11
  • Hall of Fame,
    Founding Member
Here another random bug post, rated as such.
Now for the issue, no you can't stop the phone from ringing, because you have a single line and the router has no way to know which number has been called.
