QOS
Feb 7th, 2008
Hello Question
Why this policy map works:
policy-map test
class class 1
priority 60
class class2
bandwidth percent 30
class class 3
bandwidth percent 45
According to the book under a single policy map the structure should be the same? kbps or percent but the combination should not be accepted.
Thank you,
Nils.
Overall Rating: 4 (2 ratings)
toddlerdal Fri, 02/08/2008 - 06:30
Been a few months since I read the book for QoS, but I believe that is only true outside of the priority queue that you can not mix and match.
nilslau03 Fri, 02/08/2008 - 10:47
You are right!
This example is wrong:
policy-map pmp3
class class1
priority percent 20
class class2
bandwidth 30
class class 3
This show that outside the priority queue we cannot mix the commands.
Thank you once again.
you should use either percent or hard bandwdith in kbps. you could mix it up by putting a policy map within a policy
policy map 1 could use a hard police statement not to use over 1.5mbps and policy map 2 could further define what amount of traffic each class has within either by percent or kbps.
but even then your still governed by the rule. remember that you can use only 75 percent of the bandwidth unless you remove the restriction from the interface its going to be applied. all available bandwidth should be used up in the policy map and none left over. there are alot of extra things i didn't cover but if your reading the book it will help
