royalblues Fri, 02/08/2008 - 04:54
  • Green, 3000 points or more
I dont think there is a command that can show the uptime directly
what you can do is to configure "crypto logging session" (assuming IOS). This will send the up/down messages to the syslog server from where you can calculate the time the tunnel has been up
Just remember that a tunnel can be brought down if it does not see interesting traffic for a specific amount of time. This should not be considered as a problematic event
Narayan
