Plotting Senderbase Information on a World Map
Feb 8th, 2008
Greetings,
I have whipped up a quick script some of you may find useful.
ip2mapplot.py is a Python script for resolving a number of IP addresses to latitude / longitude coordinates and plotting them on a world map
Below is an image generated from one days worth of Senderbase drops on our Ironport MGAs:
[img:f531ef1b7c]http://insecure.io/images/a/a6/Map_sbrs_small.jpg[/img:f531ef1b7c]
Source code is available here: http://research.mince.ac.nz/ip2mapplot.py
Further instructions here: http://insecure.io/index.php/Code/ip2mapplot
Cheers,
si
bpoyner_ironport Wed, 02/13/2008 - 19:57
Here's what our map looks like with one week's worth of data on hosts with a SBRS of -10 to -4.
[img:c91b0e4b2a]http://web.acd.ccac.edu/~bpoyner/ironport/ironport-map-small.jpg[/img:c9...
[+] Found 691344 unique IP addresses
[+] Determining unique latitude / longitude points
[+] Plotting 15037 discrete points on map
[-] Plotting 14098 points for x < 100
[-] Plotting 772 points for 100 < x < 500
[-] Plotting 131 points for 500 < x <2500> 2500
I don't know if anybody else ran into this issue, but as-is the script provided by si doesn't work with python 2.3. You'll get the following error message:
Traceback (most recent call last):
File "./ip2mapplot.py", line 41, in ?
latlon = count.partition(',')
AttributeError: 'str' object has no attribute 'partition'
You have to change partition to split, and change the latlon array reference accordingly.
Rayman_Jr Mon, 02/11/2008 - 14:58
Interesting to see that the SPAM pattern is very similar.
Here are my stats from yesterday (Sunday)
[img:9a11853639]http://lh5.google.fi/jari.riihimaki/R7P2JJnR4WI/AAAAAAAAAFo/G4iqE-dZUJs/...
[+] Found 289282 unique IP addresses
[+] Plotting 15950 discrete points on map
[-] Plotting 15613 points for x < 100
[-] Plotting 259 points for 100 < x < 500
[-] Plotting 64 points for 500 < x < 2500
'[-] Plotting 14 points for x > 2500
si_ironport Fri, 02/15/2008 - 01:17
Thanks for your feedback guys, jariih I have updated the documentation to include a link to download Basemap
Good point regarding python2.3 bpoyner, I only tested on v2.4
Rayman_Jr Fri, 04/08/2011 - 01:39
I used this script few years ago but now I have lost the code and I can't find it from the links bellow either.
Does anyone know where to get this code ? This was very nice script to see where the spam is really coming from
