HWIC-1ADSL-M
Answered Question
I found a pdf from 2006, with information how to configure HWIC-1ADSL-M.
http://www.cisco.com/en/US/customer/products/ps6706/products_feature_guide09186a00807d948e.html
But in the configurator this HWIC is not available.
What is going on?
I know how to configure the board, but i don't how to buy it.
help
Correct Answer by paolo bevilacqua about 9 years 2 months ago
A bit unsual request .. anyway here you go.
Be aware that to have shipment for products that are NPH you need Cisco's PM approval.
If you have partner level access:
http://www.cisco.com/cgi-bin/front.x/ltt/leadtimes.cgi
enter product number and submit.
If you don't have partner level access, the tool is not available to you.
Overall Rating: 5 (2 ratings)
paolo bevilacqua Fri, 02/08/2008 - 02:47
  • Hall of Fame,
    Founding Member
Hi, nothing is different compared to ordering a the regular non annex-M card, just make sure when you place the order, the correct part number is specified.
If any doubt contact your appropriate Cisco customer contact.
paolo bevilacqua Fri, 02/08/2008 - 03:42
  • Hall of Fame,
    Founding Member
Have them ask cisco or talk to you CAM. The card is orderable, but on NPH until March 3rd.
Correct Answer
paolo bevilacqua Fri, 02/08/2008 - 09:27
  • Hall of Fame,
    Founding Member
paolo bevilacqua Wed, 02/13/2008 - 10:13
  • Hall of Fame,
    Founding Member
Sometime they don't "like" to take orders for products that are NPH. The situation should change after march 8.
