User-Locale GB for CME 4.2
Feb 8th, 2008
I donwloaded the Localization file for GB, but when try to define the user-locale under telephony-service UK or GB is not available, only DE, DK,ES, FR, IT, JP, NL, NO, PT, RU, SE, US.
I using CME 4.2 with IOS 12.4.11XW2.
Is this a bug? How can I use the GB user-locale?
Steffen
Paolo Bevilacqua Fri, 02/08/2008 - 03:29
  • Hall of Fame,
    Founding Member
I doubt there are, as long no "color/colour" type of words are used, it's really the same language in written from. Please don't kill me now :)
Paolo Bevilacqua Fri, 02/08/2008 - 04:45
  • Hall of Fame,
    Founding Member
Yes, but it is used mainly for the network-locale portion, that is, the tone defintion in the file g3-tones.xml.
Then the strings in the jar file are really the same as default, so even if these don't get loaded, is not a problem, see below:
<?xml version="1.0" encoding="ISO-8859-1" ?>
English_United_Kingdom
... etc ..
