Amit Singh Fri, 02/08/2008 - 03:59
  • Cisco Employee,
Yes only the tagging has the priority COS field.
-amit singh
carl_townshend Fri, 02/08/2008 - 06:35
so does that mean if you want to prioritize frames, you need to make sure that the packet is tagged with a vlan ?
s.arunkumar Mon, 02/11/2008 - 03:53
  • Bronze, 100 points or more
Yes ,tagging is needed..
LAN QoS uses ClassOfservice(COS) bits for qos classification and marking.These bits are send along with vlan tag information.
For dot1q,its the 3 bit priority field and for isl tag its 3 bit from user field..
arun
carl_townshend Mon, 02/11/2008 - 05:08
so for layer 2 cos, the frame must have a vlan membership that is not tagged? so am i right in saying we cannot prioritize the native vlan ?
Kevin Dorrell Mon, 02/11/2008 - 05:33
  • Green, 3000 points or more
It is possible to have a frame with a Null tag, i.e. it looks like it is on VLAN 0. It does this, just so that it can use the 3 bits for the CoS. The zero-VLAN means native, whatever that might be.
Cisco phones often use that technique. You can configure the port as an access port. The PC sends frames like it was on a normal access port. The telephone sends frames tagged with VLAN 0 and a CoS 5. These telephone frames are implicitly on the VLAN that you have configured on the port as the voice VLAN.
Kevin Dorrell
Luxembourg.
