ACS deny remote access
Feb 8th, 2008
  • Silver, 250 points or more
What is the easiest way to deny telnet and ssh (management CLI access) to the network devices which are registered in ACS based on group levels. (excpet ACL).
So access should be granted for Admin groups for all others not permitted. Other groups need access to Remote access VPN, and Wireless.
Thanks in advance,
bye
FCS
Jagdeep Gambhir Fri, 02/08/2008 - 06:44
  • Red, 2250 points or more
FCS,
Edit the settings of that group .
Go to group you want to deny telnet. From the JUMP TO drop down menu select the option TACACS+
Under TACACS+ heading uncheck the option Shell.
Click on Submit and Restart.
YOu are done
~JG
Do rate helpful posts
farkascsgy Fri, 02/08/2008 - 07:45
JG,
Any solution for Radius, since I use radius for VPN and WiFI access authentication.
bye
FCS
