Missing ISDN Serial Interface and MGCP Statement
Feb 8th, 2008
I have a 3745 ("flash:c3745-ipvoicek9-mz.124-4.T2.bin")that keeps loosing one of its serial interfaces. As a result calls cannot be sent out this gateway even though it is still registerd with the CallManager(4.1.3ES71.
The whole mgcp statement just disappears
The work around is to reload the box out of hours. How can I resolve this isssue.
Paolo Bevilacqua Fri, 02/08/2008 - 04:48
Hi, if not needing 12.4T features, you can try 12.4(3j) that is the most stable.
Else the latest in 12.4(4)T than is now T6.
Chances are the bug is fixed in both releases.
pcameron Sat, 02/09/2008 - 20:41
Do you mean all the MGCP statements disappear, or is it that the D channel command 'isdn bind-l3 ccm-manager' is removed out of the configuration ?
