02-08-2008 05:29 AM - edited 03-15-2019 08:42 AM
Hi all,
When configuring the lines on an IP phone you can specify the "Ring Setting (Phone Idle)" and "Ring Setting (Phone Active)" parameters. One of the options you can choose is "System Default".
My question is where do you set the "System Default" for these two parameters? I can't seem to find it.
Thanks in advance for any assistance.
Solved! Go to Solution.
02-08-2008 05:54 AM
Hey Steven,
You have to dig deep for these ones :)
From ccmadmin;
Service>Service Parameters>Callmanager Service>Clusterwide Parameters (Device - Phone)
You will see the settings options here.
Hope this helps!
Rob
02-08-2008 05:54 AM
Hey Steven,
From ccmadmin;
Hope this helps!
Rob
11-19-2014 07:51 PM
We run system version 9.1.2.11900-12
It is now in System>Service Parameters>Select Server>Cisco Callmanager Service>Clusterwide Parameters (Device - Phone)
Cheers
Adam
