Fax receipt truncation
cris_jimenez
Level 2
Level 2
I have a 2851 GW, integrated with CCM 6.0
we have a few fax machines attached to ATAs and the main fax number attached to an FXS port on the GW. however most of the times when somebody sends a fax, the fax receipt is truncated and it happens randomly.
we had configured MGCP first and we changed yesterday evening to H.323 to have more resources to troubleshoot this issue.
I have a ticket open with the TAC, but it has been useless, we need to resolve this asap, because the business impact is huge
thank you very much for your help
paolo bevilacqua
Please send output of "show controllers T1". If you have slips, chances are you are missing the required network-clock-participate and select commands.
5 Replies 5
paolo bevilacqua
#show controllers t1
T1 0/0/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20060707, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (427 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
55 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
55 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
11219 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
11219 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 81 Unavail Secs
MHDFAVG01#
thank you very much
Here you go, configure:
network-clock-participate wic 0
network-clock-select T1 0/0/0 1
And you will be faxing all along (hopefully)
Please report that to the TAC engineer to help the fellow in fixing next case (it's a common occurrence).
I just issued the 2 commands and I will monitor all day long today
thank you very muchf for the prompt help
this is my case 607865329 I opened on tuesday, requested a requeue due to time zone and it took 7 hours before it was assigned to somebody and I haven't received an update
thank you very much i really appreciated it
You are welcome. Thanks for the nice rating and good luck!
