IPMA in a large company environment
Feb 8th, 2008
Does anyone actully use IPMA in a large company environment? I was always under the assumption that once you ran the wizard you were stuck and for example if you created a Route Point for IPMA with 2XXX all of your Managers and Assistants DIDs need to be in the 2XXX range. How do you guys use this in a large environment where Managers and Assistants have radically diffrent extensions. For example I have a Manager whose ext is 8701 and an Assistants that is 3597...what do I do there? Thanks guys.
gogasca Fri, 02/08/2008 - 21:48
  • Green, 3000 points or more
Create a route point but add multiple dn patterns under it. Even though IPMA
supports only one RP but it does support multiple dn patterns.
akascarface Sat, 02/09/2008 - 09:13
Do you mean in its calling search space place the partions where all the phones are? Your term "dn patterns" is what is confusing me.
