Multicast Config
Edison Ortiz Fri, 02/08/2008 - 12:49
  • Hall of Fame,
    Founding Member
Does it tell you to use Auto-RP, BSR or Static RP ?
It may be one of those CCIE type of questions where they want you to use Auto-RP on this scenario.
Auto-RP, by default, will choose the highest IP address between 2 devices (so in this case, it will choose R2). The workaround is selecting another interface with a lower IP in R2 so it can be considered a backup RP.
Please reply if that's the case.
__
Edison.
Edison Ortiz Sat, 02/09/2008 - 13:20
  • Hall of Fame,
    Founding Member
Then do as I recommended, when mapping the groups make sure the send-rp-announce is referring to an interface with a lower IP address on R2 than R1.
Usually, you pick the loopback IP but that's not mandatory. You can pick any interface from the router.
A Sample Auto-RP configuration can be found here:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/himc_c/chap05/mcbbasic.htm#wp1134342
HTH,
__
Edison.
