02-08-2008 01:37 PM - edited 03-03-2019 08:38 PM
Observing high overrun on hssi interface. Need to know if any one have idea why.
02-08-2008 02:12 PM
What router is thay, what is the output interface, what features are enabled is cef enabled ?
Also post the complete show interface.
02-08-2008 02:27 PM
Router is 3640. Its a bridge interface so lets skip cef. Here is the show interface output.
Hssi2/0 is up, line protocol is up
Hardware is M1T-HSSI-B
MTU 4470 bytes, BW 45000 Kbit, DLY 200 usec,
reliability 255/255, txload 1/255, rxload 6/255
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 05:13:27
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 1208000 bits/sec, 194 packets/sec
30 second output rate 177000 bits/sec, 160 packets/sec
2414032 packets input, 2115674222 bytes, 0 no buffer
Received 218401 broadcasts, 0 runts, 0 giants, 0 throttles
0 parity
8867 input errors, 0 CRC, 0 frame, 8866 overrun, 0 ignored, 1 abort
02-08-2008 03:42 PM
Hi, on a slow platform like 3640 you have like 0.3% total overruns, it should not be a problem.
Also converting to regular routing should help.
02-11-2008 11:07 AM
Any cisco docs on this, which says that the overrun on 3640 with hssi interface is common.
This would help me very much.
02-11-2008 11:30 AM
Not really, on the other hand is understood that the 3640 is not adequate to deal with the traffic bursts typically associated with hssi and bridging.
