mattcalderon Fri, 02/08/2008 - 14:24
  • Silver, 250 points or more
try a shut on the actual channel
voice-port 0/0/0:23.1
shut
Have not done this, I dont think, but it may work
paolo bevilacqua Fri, 02/08/2008 - 14:30
  • Hall of Fame,
    Founding Member
No it doesn't. First the .1 notation refers to a subinterface that doesn't exists, then the only voice port that exist is 0/0/0:23, not 0/0/0:1.
mattcalderon Sat, 02/09/2008 - 15:43
I am not talking about the serial subinterface. I just verified on my 2811 running c2800nm-spservicesk9-mz.123-11.T10.bin that when i go to config mode and then type voice-port 0/0/0:23.1 i can enter the channel and puts me in config-voiceport mode. You actually have most of the config commands that you would for a normal voice-port. I remembered this because I had to busyout a particular channel before
paolo bevilacqua Sat, 02/09/2008 - 16:28
  • Hall of Fame,
    Founding Member
You are right, I have tried and one can enter a notation indicating a timeslot after dot, however is taken as a synonymous for the port without the dot, so you end shutdown the D channel.
paolo bevilacqua Fri, 02/08/2008 - 14:25
  • Hall of Fame,
    Founding Member
Try "show call active voice comapct", find ID, then clear call voice causecode 1 calling-number XXX. There is also an ID option.
Not sure if that works if you're using MGCP. If you have a badly stuck call however the above is not enough.
