Wildcard mask
Feb 8th, 2008
Hi seniors, On production router,I want to deny three hosts
1.10.5.9.7/24
2.10.5.10.7/24
3.10.5.11.7/24
What is your suggession
a.Should use separate access-list for three
b.Should combine (& how)
Best Regards, Tahir
Istvan_Rabai Fri, 02/08/2008 - 19:08
Hi Tahir,
You can try the following access-list:
access-list 1 deny 10.5.8.7 0.0.3.0
This will only deny the mentioned 3 hosts.
Cheers:
Istvan
Istvan_Rabai Fri, 02/08/2008 - 19:32
Sorry Tahir,
I'm sleepy...
access-list 1 permit any any
This will also deny host 10.5.8.7 /24, but from your post I assume you don't have that subnet at all.
Cheers:
Istvan
Istvan_Rabai Fri, 02/08/2008 - 19:54
Oh, this is incredible !
I really have to go to sleep now :)
I typed too many "any"s.
Istvan
aijaz802 Sat, 02/09/2008 - 05:02
Hi Tahir,
I suggest to use 3 separate ACLs, assumed that the subnet 10.5.8.0 is used in network. Otherwise use combined ACLS as suggested by Istvan. But in this case one subnet will be wasted.
Thanks..
*aijaz*
