CVP SigDigits and Multiple Transfers
I am looking at using the CVP SigDigits functionality in a H.323 environment in order to support a distributed branch topology. If I use the SigDigits to change the H.323 Tech Prefix for VRU leg setup on the local VXML Gateway (not co-resident with the ingress GW), does that new Tech Prefix carry through for a subsequent call transfer from CVP Self Service to an agent on a CallManager?
hadbou Thu, 02/14/2008 - 11:40
  • Bronze, 100 points or more
In many cases, most of the Directory Number (DN) reachability issues are associated with duplicate DNs. The best way to resolve these issues is to generate a route plan report and review it carefully.
The route plan report also allows you to save report data into a .csv file that you can import into other applications. The .csv file contains more detailed information than the web pages, including DNs for phones, route patterns and translation patterns.
